1 - 8 of 8 Posts
I have a cam that i had in my old Corvette,and it has a little rust on it I would like to replace it with the same spec's
any info would be apprichated
These are the numbers on the end of the cam
Enforcer 11
306H06
C
D
11 46 86
I am shure that it's a hyd cam..?
Thanks Tony
If you list the existing combination, maybe we can get you closer to what you should go with? Comp makes a very good XE grind for hydraulic flat tappets as does Lunati with their VooDoo series. Let us know.
This cam came out of my corvette,small block ,350 with bow tie heads, I just like the cam ,it performed very well.
Thanks Tony
Got ya...have any idea who makes the cam you have? Otherwise you would either need to degree it and see what it is, or find someone with a cam doctor.
Its a Cam Dynamics cam ,the abrevation on the end is C
D
Thanks Tony
Butch
I would replace it with a Crane 302H06
246/246 @.050" .500"/.500" 106 lobe seperation
Discussion Starter · #8 ·
Thanks for the info trmnatr........................I think thats the cam............ 500/300
found out the crane bought out cam dynamics.............went to cranes site and got the cam card.
Thanks Again......................... :)
Tony
1 - 8 of 8 Posts
