1 - 10 of 10 Posts
Started to put the caltracks on my truck and the aluminum bushing is way to small to fit the front of the leafspring. The id of the spring is roughly 2 inches and the bushing is only 1.5 inches? and calvert only list one size????? Anyone else run into this on a late model s-10... thanks.
No, just the factory leafs off of a 2001. I have been doing a little research and i think the later models have a larger front bushing...
My springs come off a extreme truck they have the factory 3 inch drop springs. Mine fit fine but when I bought them I think they come with 2 sets of bushings and one had a larger od than the other if I can find the smaller ones I will measure them this weekend and get back with u
that would be great. i called calvert and they said all s-10 were the same...... not true.
Discussion Starter #7
I think im just going to get the calvert split monos, i do want to go with the 2" drop spring as the truck sits low and i want to keep it that way. What # spring are most of you using on the s-10s with the cell and battery in the rear? thanks.
Discussion Starter #10
i just talked to a local machine shop and they can do a bushing to fit $35 for the set. I may try the stockers before i get the calverts 35 is much better than 400 at the moment.
1 - 10 of 10 Posts
