I've only made about 8 1/8 mile passes with the current setup.
Here's the rundown:
70 Charger, 3900 with driver
453 C.I., naturally aspirated, estimated 600 HP
727 trans with low gear set, 2.74 first gear
9.5'' Dynamic converter; 4,300 flash
4.10's with 325/50/15 M/T drag radials set at 18 PSI
90/10 Caltrac shocks up front, Rancho 9-ways in the rear with Caltrac monoleafs and Caltrac bars. The monoleafs are -1 inch and the car also has 2'' steel lowering blocks.
The bars are currently set in the bottom hole, driver's side shock set at 5, passenger side set at 7. I'd have to check preload as the car was torn apart and put back together over a 4-year span and I left everything how it was when last ran. I have pulled a best 60' of 1.502 with the next best 60's of 1.53 and 1.55. I've done some reading on here and it seems you want to put a lot of pressure on a drag radial and both rear shocks should be set the same. I just hoping someone could give me a good starting point for my setup. Here's a couple pics and video from last weekend. I know they aren't the optimum angle, but it's all I have. Thanks guys!
Here's the rundown:
