1 - 7 of 7 Posts
can anyone tell me if a c7 or 67 valve body will work in a late 70s case it is a trans brake valve body and if so does anyone know where I can get a deep filter for that app
both cases are E2 or 82 i have inspected both valve bodys and all holes seem to be the same can any one tell me what the difference is
The main difference may be in the detent . The 67 vb has the detent in the manual valve of the valve body and the 70 has the detent in the rooster comb on the case, the manual valve moves freely when not installed in the case.on the late vb... I believe you can install that vb in the late case but you have to modify / grind the rooster comb to clear the early vb. Grind all the notches off the rooster comb and check the fit.....As you state all the feed holes are lined up.............
I had the valve body bolted in and no clearence problems .I dont know who made the 67 valve body but I am putting it in the place of a PA
1 - 7 of 7 Posts
