1 - 5 of 5 Posts
Below is the picture of the stock piston on the left. On the right is the piston and spring that came with the solenoid.
There was no spring between the stock piston and trans case.
I just wanna make sure its right the first time it goes together.
Discussion Starter · #2 ·
In what order does it all go together? I didnt get any instructions ( used )
Case | Spring | Piston | Solenoid
or
Case | Piston | Spring | Solenoid
I cant see that option two would work because the piston just sinks into the case.. If the spring goes in first then the piston will move a little bit....BUT It sure doesnt look like the solenoid will screw into the case very far at all with the spring and piston in place.
Help PLEASE ASAP!
Exactly.....
Have you got the modulator hole threaded yet?
Exactly.....
Not yet. Doing that tonight. Was just looking at parts and trying to determine how it all went together before threading the hole.
1 - 5 of 5 Posts
