1 - 10 of 10 Posts
Besides the bell housing from JW, What else will be needed to make this mate happen? Is there a convertor bushing needed for this like I had to have with a th400 to a sbf? Thanks for the help fellas.
Either a flexplate or the converter built to spec for the application of LS motor to C4.. The converter setup may be an easier option as pointed out this is not a common setup
Very easy
TCI flex plate and UCC 1/2 chevy 1/2 ford converter. Call Lenny he did mine and it is working great.
Tim
You can always make custom pieces to work and adapt but do you really want to do all this just to run a C4? Just wondering.
Hutch
yep...... ;)
I really like the C4 trans. A tight small package. With a few beefy parts will take plenty of power. With the power levels LS motors are known to make, the C4 may be over powered.
My C4 in the 1962 Falcon I run has held up great for 3 yrs now.. of course there is only a mild angry 200 CID inline Ford 6 in front of it.
:yawinkle:
My c4 has a lifetime warranty and it was paid for. Would have cost a pile of $$ to switch to a 350. Trans, shifter mod, shield, bell, drivshaft.
Tim
1 - 10 of 10 Posts
