I have a c4 behind a 800 hp 410 (on spray) and have had a problem almost every pass after I go into 3rd gear the car starts smoking. Fluid level is rite according to the stick, I'm assuming it's coming from the vent on top of the case. This leak is a hard one to chase down due to it happening at wot under a load, the trans has always had a slight flare on 1-2 and 2-3, it was really bad with the tci manual vb, went to a pa and got better, still slightly there. I need to put a bigger trans cooler on it that I have, it has a 4200 conv and tci servo pa rev man valve body, let me know where to start, thanks in advance
