1 - 5 of 5 Posts
So I bought a deep pan a few years ago and the filter that was supplied was the wrong bolt pattern. I have an early C4 valve body (pre-70) and can't find a deep filter. Doess anybody have a part number for the filter or a filter extension?
Thanks,
Jason
I ran mine with a normal filter and deep pan w/o trouble. The level is still the same compared to the pick up and I have never seen a deep filter for an early valvebody.
So when you ran a normal filer did you just use all the bolt holes?
Thanks,
Jason
I used the filter that the early C4 calls for. It was not even close to the bottom of the pan, but stayed covered. I went to a newer C4 now with a deep filter.
1 - 5 of 5 Posts
