1 - 3 of 3 Posts
I am doing a 410" motor windsor block and the c302b heads.As far as head gaskets do i need to use an svo gasket i have a 4.100 bore now and it fits the comp chamber every where but around the intake and exhast valves.I know the svo gaskets are not round bore and have the valve relaifs in then any help from people that have used the heads would be greatly appreated.
I have C302s on my 74 Windsor block. I used Cleveland head gaskets, all i had to do is use black rtv in the front where it hung over a little where it mates with the intake. If you have any questions you can PM here or go to TNR. (www.toonutsracing.com/smf) We have some good Cleveland dudes over there.
1 - 3 of 3 Posts
