1 - 8 of 8 Posts
What are the pros and cons if I switch from 16 to 23?? Sb NOS motor. What’s the determining factor of going up to 23?
C16 not even designed for na or nitrous environment.Do a little research and you will find far superior fuel for nitrous use.
From VP:
PRODUCT DESCRIPTION
Established a performance standard that still exists today for use in turbocharged engines, supercharged engines and nitrous applications with CRs up to 17:1. C16 is one of VP’s most popular blends.
Lots of racers use C16 just for the high octane rating. But it is a heavy specific gravity blend with minimum light ends that help start the combustion on N/A engines. It also is good where high temperatures are unavoidable like supercharged or turbocharge engines. That won't help N/A Engines either. JMO.
From VP:
PRODUCT DESCRIPTION
U can use for nitrous if you want but look at all specifics on it.Designed for high heat apps.Pretty much opposite of nitrous environment.I look for ways to put heat back in on big nitrous hits.But each their own.
bingo you get it .
To me it depends how hard you are spraying it, are you looking for max power like class racing and so on. Regardless of what's said C 16 is still the most commonly used nitrous fuel in the game.. Not saying it's right or wrong, just very common.
1 - 8 of 8 Posts
