i have a ptc built c-4 that has performed flawlessly for about 3 years
well the other week the factory oem bell housing cracked in the starter mounting area
i bought a quick time bell housing and when installing it a few of the front pump bolts stripped out
so i pulled the pump out to heli coil the case
put a new gasket on reinstalled the pump and made sure the washer thing was in the back of the pump in the holes so it fit flush
i noticed another washer has dropped it appears to be a thrust washer back past the end of where the input shaft goes
i am sure this is clear as mud
any help appreciated
