1 - 20 of 173 Posts
im looking to see who uses them,what r the combos,horsepower and ET numbers.looking at using one in a 68 camaro with a 5.3.lets see them.thanks
Boosted Bowtie's combo pretty much says it all.
4450 pound truck. 383 with a standard cover 87mm turbine S480.
[email protected] mph.
1000-1100 hp @ the crank to run that number at that weight.
I can divulge this number, 5.6x at 128ish on a 1.5 60ft on a 347ci sbf in a fox at around 3450 with a driver, maybe a tad heavier, never scaled that car. I have seen one put up low 160's all in however, but thats using a bullseye s480 race cover model with t6 hotside. Both cars had the bullseye race cover turbo, the sbf ran a 1.25 ar hotside with a 87mm turbine if my memory ain't to fuzzy
Allot of power if that was your question. I know there are some people that have been faster, but thats from vehicles I can talk about.
5.60's all day with on 18psi on a sbc. 1.30 60' with a Bullseye s480 with race cover. this was @3250 lbs with a T6 hotside.
306ci Fox body @ 3348 weight, S400-80 billet with race cover and 92mm LDP turbine wheel, T6 1.25A/R, went [email protected] Same car with cast 82mm wheel upgrade went [email protected] 2 weeks ago. Boost is not dropping off and back pressure is still in check. I figure the customers car with everything but the kitchen sink will do 135-137max with the 82 and 133-135 with the 80 if he had pushed it. He is working on the converter to get the car off the line harder.
Damn I hope my 306 s400-80 combo works That good. I've got a 1.25/ar but with a 87mm turbine. You know what heads are on this car and cam specs?
Is your T4 or T6. AFR's I believe are on it. I can find out for sure though.
363 t4 s380r, box stock 205 heads, full weight with ac full exhuast and tips, 3400plus lb's, 882 rwhp, 1.35 60ft 5.69 122mph 19lb's boost
Discussion Starter #13
thanks keep them coming.my plan is to run a stock 5.3.i may upgrade valve springs,head gaskets,arp bolts and pushrods.id like to use stock heads,truck intake or car intake.i will be using 93 octane gas.car weighs 3500lbs with a iron headed bbc,th 4000,4500 converter,12 bolt rear.i plan on running a air to air innercooler.it will be 20% street 80% track.i like the idea of it running good on the street but the track is the most important to me.ps i will drive the car to the track.thanks for the help.
Discussion Starter #14
can i get the power i want with a t4 or do i need to use a t6.i am shooting for low to mid 9s for starters.we do not have but one tunner up in my neck of the woods so i want to see what i can get way with usin a mostly stock 5.3 and save my money and build a good one once my tune is figured out.i justttt dont want to spend some good cash and watch it burn up because i dont know enough about the tune.oh buy the way we have no good air.da at race day is 6500 up thanks.i also would like to keep it FI.
5.30's with lousy 1.35 sixtys at 136mph with hyd cam 339ci with old high ports at 3250
BW Cover
These turbos are great.
nice what rpm and spring pressure???
imho there is no reason when starting from scratch to not go to the t6 flange turbo. package it nice now and make it all fit so down the road all you might have to do is put a bigger exhaust housing on.
6700 and I cant remember the seat pressure. I set it up like a Renegade car. Run a solid now and a slightly better head now. With some good sixty footers I look to run 20's this year. These turbos work great. with the 5.3 you should do well.
Went 151pmh @ 3475 pounds with a s480 with a bullseye cover!
1 - 20 of 173 Posts
