Well my car melted a couple pistons in the stock 302 block, and I'm leaning towards building a DART block setup. If I go that route, why not boost it right? I'm been missing my old turbo car lately...
Combo would be a 347" sbf, AFR185 heads, TFS R intake, custom hotside kit. Street driven with AC and PS. Mostly would keep boost at 7-10psi for daily driving and turn it up for track events.
Using the borg warner matchbot, for a twin setup(Believe these will be easier to package and run the exhaust out the back than a big single) the little 62mm units look good all the way from 10psi up to over 20psi, but I'm falling off the map at 7psi. The 66mm units look good everywhere in that range. I was thinking of using the 0.91ar T4 twin scroll housing for either unit, any other recommendations?
Is there any reason to go with the 62mm over the 66s? I assume spool time will be a tiny bit slower but nothing major?
