1 - 3 of 3 Posts
what would cause you to burn up rotors after 10 passes what should i look for it is a 8 plus stacked with a 7531.crank trigger and fast xfi.
rotor could be out of phase
Also, make sure the tab on the rotor is bent "up" enough to conact the button on the cap. Otherwise the button will be eaten away by the resulting spark, and if used for a long enough period of time heat can build up melting a portion of the cap or rotor.
1 - 3 of 3 Posts
