1 - 13 of 13 Posts
this is a friends motor and im posting this in hopes that you guys can help diagnose what happened. obviously detonation but im not exactly sure why. this was cylinder #4. the others look ok and the bearings are all still perfect. Here is the combo. 374 cubic inches (4.125" bore - 3.500" stroke), JE flattops, AFR 210 eliminator heads (75cc chamber for 9.3 compression ratio), mechanical flat tappet (252* in at 0.050" - 260* ex. at 0.050, 1.6 intake rockers, 1.5 exhaust rockers), Super Victor intake with some plenum work, CSU 830 carb, e-bay turbos with the following specs - 57mm x 75mm x 0.070 A/R cold side - 58mm x 74mm - 0.068 A/R hot side T4 compressor and turbine. Homemade log style manifolds. Air to air intercooler. TH400 with custom 9 1/2" converter, GearVendors and 3.73 gears. 28 x 10.5 slicks, car weight approx. 3800 lbs. Hadn't gone over 15 lbs with this setup on turbo's yet, had run over 20 with previous Procharger setup. Timing on this pass was 28* using 93 octane.
turbos are very restrictive on the turbine side....cam all wrong...terrible reversion....just a couple things to begin with.
inlet temps are hotter on a turbo then a procharger!! intercooled?? back some timing out of that thing!! 28 degrees on pumpgas?? prochargers loose boost on the shift, and turbos make boost on the shift!! i have seen boost go waaay up on the shift!! but the procharger falls off because the crank slows down on the shift. but the turbo wont fall!! a bad boost spike.... and 28 degrees timing, on pumpgas.=:confused:
way too much timing for pump gas
Maybe pistons are a bit weak for this application. But for sure your exhaust A/R and big cam don't match.
I run almost the same engine (with bigger turbos and more boost) with 93 octane and water injection at a rate of 20 - 30 Gph no detonation.
Just curious, what is your speed with 3800lbs ?
Custom Engine Shop
waaaay too much spark for 93, and yes the ring lands appear to be thin.
If the exhaust housings are small and the cam has a bit of overlap you may be able to run that much spark because of an unintended EGR...
I rarely run more than 20* of spark on a pumpgas, boosted pushrod motor...
Discussion Starter · #11 ·
thanks for the help guys :cool:. i havent heard from him today so i will answer some of the other questions when i do. ill try to get him to join so theres no third party issues.
Hey everybody, thanks for the advice so far, some of the stuff you pointed out I knew wasn't quite right, but some of it I don't know - that's why I'm here - trying to learn.
Yep, I agree. This was still the cam I used for the Procharger setup. I left it in there to do some debugging. I knew it wasn't going to make the most power possible, just didn't think it completely through about possibly killing the motor.
Yep, when I ran the Procharger with the Powerstroke intercooler it would make 15 lbs. at the shift and drop to 12 when rpm's dropped. I never saw any spikes from the turbo setup when I datalogged it.
Piston is too thin near the intake valve relief.
Ring package to high,
Yep, these are pistons for a N/A application (JE's), but I figured if I could keep a sorta safe tune in it, they would be o.k. They're in there because I got a good deal on them.
I'm basing my timing on my Procharger experience. I had a 383 in the car before this one. It had almost 10 - 1 compression with iron heads and I ran 15 lbs. boost on it also. I ran it on a chassis dyno and it made 20 more h.p. when I bumped timing from 28* - 30* for a total of 609 r.w.h.p. Since this setup had less compression and aluminum heads I figured 28* was a safe setting since I increased the water injection nozzle at the same time. However turbo's are obviously different and I think camshaft really killed it - but that's why I'm here and I will start with lower timing next time. I'm also done with pump gas at the track - the not knowing what you have factor doesn't make it worth it anymore.
My best time with the Procharger has been a 9.54 at almost 142 m.p.h. I had 28 x 9 slicks at the time and had to roll into it to launch. 60' was a 1.429 on that pass.
Was he running any kind of wideband? What did the a/f look like?
I do have a wideband (Innovate). I have it tuned to run in the 11.8 range. Here is where carma comes in - the sensor quit working when I unloaded it off the trailer. I haven't seen really any variation in the a.f.r. in the past but what sucks is I can't say for sure on this pass.
As far as exhaust housing size - this is where I flat out don't know. These are e-bay turbo's (figured I would start cheap to learn) so I had to take what I could get. Are they in the ball park to support around 500 h.p. each? I have looked around for months at camshaft specs people are running in various combo's and they are all over everywhere. I realize I definately need to drop some duration and widen the seperation. The question is how far. It will be a mechanical flat tappet setup since I drive it far more on the street than race it. I'm guessing something in the high 240's on in. and ex. at 0.050" with maybe 116* seperation????? Thanks for the input, keep it coming. Clay
1 - 13 of 13 Posts
