yea a 3 step helps i had pretty good luck with just a two stepHave a car with batch fire FAST Sytem.
Has P/G with trans brake and a digital 6 box
What can I use to help spool the turbo while on the brake?
I head something about a 3 step but that won't work with a Digatial6 correct?
Different Turbine A/R3 step RPM set as high as you can without pushing through the brakes
More timing
Lossen the converter
Thats great but you need to get the R/T down if you plan on winning any races.
