1 - 20 of 53 Posts
Building it for a class? What's the power plant?
Sweet car!
Discussion Starter #9
Sweet car!
Dont have time to class race, would like to make most of the races at Valdosta when they do the Radial vs Slick and stuff like that.
383 SBC
PT-114
BS3
Race Pak
Moran 500lb injectors
MSD-10
AMS-1000
Aeromotive cam driven fuel pump
Dry Sump setup
Discussion Starter #10
Strange 40 spline gun drilled axles, strange double adjustables for the rear and strange singles for the front, aerospace duel brake setup. for 9 inch.
Fastest mustang roller
Good looking ride. Looks to be a good car for some true ten five racing.
Discussion Starter #17
what kind of heads?
right now I have the AFR 235s with the spread port, inconel exaust valves, titanium retainers, fully CNC'd, big block springs, cam motion camshaft.
going to use this motor to get the car going and later on build something in the 400ci range with maybe some CFE turbo heads.
Discussion Starter #19
What did you wrap the box with?
I got the box out of Hardcore racing Firebird, a friend of mine bought the rolling chassis from a auction.
it is vinyl that looks like carbon fiber and the inside of the vinyl is insulated, then they sewed Velcro on the inside to hold it together. I just sent it to Chisled to have the cooler and pump installed.
1 - 20 of 53 Posts
