You need to hit that tire a little harder Ed. The more pissed off the car sounded the better it worked. I am sure you were making changes..
Congrats!
Chris
Congrats!
Chris
yes that was him. we were both there playing around someDid I see you at the cecil behind me in the staging lanes Saturday?
Definitely a lot of car for the money Ed... Someone will be getting a great piece!********************FORSALE ********************
chassis
1993 mustang hatch (clean title)
factory firewall/floors
25.5 cert cage chromoly (just recerted)
racecraft steering column
schoneck 11" nose, harwood flat hood, factory panels/glass
self made alum wing strutless
smoked headlights/clear tail lights
bogart bolted r/t wheels with single champion bead lock
motor
boss302 block m-6010-boss302
4.125 bore 3.25 stroke 11:1cr
eagle forged crank and h-beams w/ arp2000
TEA cnc225cc highports
super vic carb style efi manifold
6061 elbow 90mm t-body
LJMS custom solid roller/morel tie bar lifters
harland sharp rockers and tfs girdle
moroso T pan
s476 billet wheel (forced inductions)
custom headers and turbo kit done by me.
true twin scroll/divided setup (spools fast)
spearco 2000 intercooler
trans
powerglide (basically an ATI superglide)
ATI sfi case w/ roller tail
billet pump and valve body
ati catch can on pan.
deep pan
1.80 straight cut gears
UCC converter
rear
8.8 stock width
3.90 pro gear
welded tubes with brace across bottom ties in LCA mounts, coil over bracket, center section
33 spline moser axels with spool
c-clip eliminators
racecraft bolt on LCA brackets
aerospace 4 piston drag brakes 4 corners
suspension
upr pro series LCA and UCA
racecraft biggest anti roll bar (1 3/8)
upr k-member and a-arms
strange double rear shocks
strange single front struts
electronics
holley dominator efi
individual coil per cylinder (ls truck coils)
exploer cam sync
aerospace crank trigger
painless switch and relay kit.
has wiring board to make changes/upgrades simple
boost control done thru efi with c02
performance
car has been [email protected] on 14lbs leaving soft 1.25 60' (3500rpm 7lbs)
just tested on a junk track and went 175mph to the 1/4 on 18lbs.(spun thru 60')
issues
intercooler is a bit restrictive and car will only make about 21lbs.
motor currently needs head gaskets. no tuning issues just a SBF lol
decided to go a different direction in life and tired of trying to keep up
going back to street cars ect
$25k obo call or text 215-880-8138
Definitely a good deal for someone.Definitely a lot of car for the money Ed... Someone will be getting a great piece!
Chris
chassis
motor
moroso T pan
trans
deep pan
UCC converter
rear
8.8 stock width
3.90 pro gear
c-clip eliminators
suspension
electronics
exploer cam sync
performance
issues
will do bud. hope the holidays were good to you and yoursI honestly can not believe this hasn't sold yet. killer car done right!
good luck Ed tell the family I said hi
Lol i like that. Ill let pops know.Awesome car for the money!
Best of luck with the next chapter of life and all the best to you and the family!
Say HI to Pop's for me.
...and now you can cruise "Ed Money" in that Audi
