1 - 20 of 2558 Posts
Discussion Starter #2
4th post.... Cant tell if its the picture angle or what..... But the alternator looks to be a smidge too far forward... Belt doesnt look parrallel to the motorplate....
Discussion Starter #8
i think your right. havent gotten that far yet just wanted to make sure it was going to fit. kind of tight to the exhaust. i picked up a horizontal/vertical band saw and all i can sat is WOW. makes fitting pipe wayyyyyy easier
Build looks great!! Which bandsaw did you get? How do you like it? I have a craftsman vertical wood cutting bandsaw that i put a metal blade on. I cant slow it down enough to make it cut straight on flat stock, but it works great on tubing. Ive been thinking about getting something different.
Discussion Starter #11
its a shop fox w1715. it was 250 bucks plus i picked up a bi metal blade. i just made my motor plate tabs out of flat stock and it is perfectly square. almost to good now i see where things looked straight but really arent lol plus you cant beat setting it at a specific angle with tubing and cut it and it is a perfect fit up after you de-bur it . i tig weld everything i can and it makes that part nice.
http://www.woodstockint.com/3-4-HP-Metal-Cutting-Bandsaw/W1715/
i know its cheap and i looked for usa specific made stuff but 1500 bills is hard to justify for 1-2 turbo kits. i figured if i can get 2000 cuts with it its like $1.25 a cut. then buy a new one. i do expect it to last longer tho
Discussion Starter #12
i do believe northern tool has a red version of it just a different name about the same money if there is one near you there wasnt for me
Discussion Starter #13
Discussion Starter #14
Discussion Starter #15
Discussion Starter #16
Discussion Starter #17
Discussion Starter #18
anyone know how much tighter a -12 low profile fitting is vs a standard?? pass side is realllllllyyy tight to the motor plate/down pipe. probably going to have to weld some fittings onto the motor plate to save some extra space. either that or dimple in the down pipe for clearance.
Discussion Starter #20
started life as a comp engineering. then i cut the angles on them
