Can someone tell me which sensor I need? Thanks.
Yes it does. That is what I use on the Strange Ultra cases. Just make sure it is the 2 wire and not the 3 wire. Positive is at the point on the Racepak SensorThank you. Do you know if the racepak sensor works? :smt102
You will have to fab up the sensor mount but for the collar we just use a Racepak one. I have them available in 2-4-8 magnet configurations. You will have to machine a slight part of the yoke and then fab up the bracket.I am resarching what is needed for a magnet ring for a Moser 1350 on an 8.8.
It can be configured for either. You can also use 8 to get even more resolution.Joe,
for the bs3 do you need 2 or 4 magnets
What about for a 12 bolt?You will have to fab up the sensor mount but for the collar we just use a Racepak one. I have them available in 2-4-8 magnet configurations. You will have to machine a slight part of the yoke and then fab up the bracket.
You have to fab up a bracket for that also. I drilled and tapped the cast webbing on the 12 bolt to mount the bracket to. The bracket was just a piece of aluminum with a 90 degree bend and a hole drilled to accept the sensor.What about for a 12 bolt?
Sounds easy enough. Got a part number for the 8 magnet wheel?You have to fab up a bracket for that also. I drilled and tapped the cast webbing on the 12 bolt to mount the bracket to. The bracket was just a piece of aluminum with a 90 degree bend and a hole drilled to accept the sensor.
The 8 magnet collar is not available for all yoke sizes. Measure your yoke and let me know what size it is.Sounds easy enough. Got a part number for the 8 magnet wheel?
