1 - 8 of 8 Posts
Well it did this several times and then after running it last night it acts like it is hung between low and reverse because if you try either gear it acts bound up. I had to load it in high gear.
shift linkage issue? I had my shifter go out of whack on me and I went WOT to neutral a few times...scary.:) Check pins/cable/mounting bolts...
Hopefully it's a fluid issue, goodluck!
Discussion Starter · #7 ·
I would have a close look at the servo.
Hutch
Thanks Hutch but I am looking at buying one from Neal. This one has ALL good parts but has a stock case and I have had bad luck with it already so I think I am going with a new trans. Probably Neal but I have not ruled out Abruzzi until I can talk with them on Monday.
1 - 8 of 8 Posts
