1 - 5 of 5 Posts
I am in need of a replacement intake for the heads I have I Need a low profile intake to fit under my hood .
I called brodix and they siad I need a 10 degree intake base manifold that they don't make for my heads.
I dont want to get new heads ,pistons. any of you gurus have any thoughts.
thanks in advance
Edelbrock 2967 is 6" tall at pad.Thick gasket and some port work you could get it to align.Might need adjustable base dizzy.Would be bout 1-1/2 " shorter than 1800 hv
Thanks for the reply...I will look into it.. When I last edelbrock rpm heads and a rpm intake I had to use a drop air cleaner and that was tight...
These heads and intake are going to be a hard sell imho.
EFI/N2O JUNKIE
I made a normal Brodix intake designed for regular 23* heads work with my All Pro RR heads, had to add material at the top of the ports so I had a decent amount of material there for the gasket, and put a slip collar on my distributor, but it came out fine.
1 - 5 of 5 Posts
