1 - 6 of 6 Posts
I have a pretty new SBC that was built by Dart and I have always had a problem with oil blowing out the breather.
The passenger side valve cover I have a PCV going to the carburetor and then the drivers side is an open breather filter.
I have a problem with the filter blowing oil mist out the side of it and seeing it lightly on the drivers side inner fender well area. These are low profile, standard issue valve covers that do have a internal metal baffle. Any suggestions would be great.
There is a baffle in the valve covers. I am not sure what the rings are gapped at but I think it is a little looser since I told them I was going to run nitrous
if its a fresh build rings havent sealed yet,you might try an evac sys.to help seal it up other than that???maybe 2 pcv's
1 - 6 of 6 Posts
