1 - 4 of 4 Posts
i currently have little (1 or 2 piston not sure)wilwood calipers and drilled rotors on the front of a 2800lb 8sec car with drums on a 9in rear there is no booster on it it is a drag car only Im thinking of upgrading the rear to disks The issue i have is i would end up with 4 piston dynalites on the rear would this work with what i have currently on the front or would i be better off putting the small calipers on the rear and the larger 4 piston (that im yet to buy)on the front Thanks in advance for your opinions on this
its no problem having the 4 piston calipers on the rear,
i run 4x 4 piston calipers on the rear of mine mate.
You would be fine with the 4 piston kit on the rear. On a drag car you want to have the majority of your stopping power come from the back because you have a much larger tire back there. The other way around and it becomes too easy to lock the tiny front tires up.
1 - 4 of 4 Posts
