What are you guys seeing for brake pressures with a foot brake setup? And what are you running for pressure to the front?
I have a Mark Williams Chrysler style master,foot pedal,Wilwood 4 piston rears,Wilwood spot calipers in the front,steel rotors front and rear
I only see 700psi to the rears and 150psi to the fronts. My rear brakes go to the front port of the master and fronts go to the rear port with a Wilwood proportioning inline. Should both ports be tee'd together?
