1 - 17 of 17 Posts
· Registered
Is there a better tubing than just auto parts tubing? Using an Eastwood 37* double flair tool and the tubing splits on the outside edge of flair.
· Registered
Your not trying to double flare stainless tubing are you? It won’t work and only requires a single 37* flare with a tubing nut. Any 37* flare will always be a single flare with a tubing nut. A drop of oil beneath the flaring cone will also help make smooth flares.
· Registered
Discussion Starter · #4 ·
I have a good deburing tool, its the coated type steel tubing. I thought all brake tubing had to be double flaired.
· Registered
45* flares for steel tubing should be double flared. Stainless steel tubing is nearly impossible to double flare without cracking. 37* flares used on steel/stainless only require a single flare backed up by a tubing nut inside the hydraulic nut. 👍
· Registered
Everything i have ever been told or read says ALL brake line must be double flaired since it is high preasue.
· Registered
You want serious brake line, the stainless from online tube is insanely strong. Makes anything else you buy look like china dogshit. Warning, you will need a serious flaring tool, like a Master Cool.
This is what I used when I built the brake set-up on my car. The burst rating was 10K PSI. All my lines are 1/4 and they are double flared. I had one of those high dollar tools that did not work worth a shit. Maybe I was using it wrong. I borrowed a cheap KD Tools double flare kit and had zero problems flaring the ends. I did have one or two flares crack but it was always something I did wrong. Till this day zero leaks.
· Registered
Did you mean Inline tube? If so I had them make some SS brake lines and 1/2" SS Fuel line for my 70 Mustang and it was excellent.
  • Like
Reactions: DualQuadDave
· Registered
Steel brake tubing is manufactured from a flat piece of steel that is rolled into a tube and fused,much like the way common chassis tubing and exhaust tubing is made. It requires a double flare to prevent leaks at the point where the seam is.
Stainless steel tubing is a DOM (Drawn Over Mandrel) product,and has no seam. A proper 37º flaring tool will only form the flare without squeezing the flare any thinner,making it equally as strong as a double flare on steel tubing,when used with a tube nut behind it.
Auto part Electronic device Jewellery Metal Electronics accessory
1 - 17 of 17 Posts
