1 - 2 of 2 Posts
Took my car around the block and the brakes at the end where so mushie it didn't want to stop. I have 4 wheel aerospace disc. I guess they are only good for a short blasts? I had no problem at ennis (157mph no chutes). The Car has setup for 3 months. Should I drain the system and start over with fresh fluid again or try to bleed them. Just seems like they should hold up better.:confused:
might have a leak or a tiny amount of moisture in the system. would definately rebleed the system. rr, lr, rf, and the lf last.
1 - 2 of 2 Posts
