The first run of 950 that is due Jan 10th is already sold. The second run of 950 is due Mid Feb. If you need batteries in a hurry the best thing to do is call Summit or Jegs or your local speed shop and get them on order now so that when they arrive you will already be on the list. Another thing on the batteries that people need to know is, these are the AGM type. They are a true sealed unit which means that they can be mounted any way you want and they will not leak. The most important thing to know is that a standard 16 volt charger will not work with the AGM series battery. Those chargers charge to at to high a voltage and will damage the battery. We are offering a charger that will charge ANY battery you have. It will charge 12,16 and 16 volt AGM batteries. If you need any more information just call me at 800-862-7223-EXT 1207
