1 - 11 of 11 Posts
1st pass on 275 DR tring to get it setup better for the import vs domestic at MIR.
[video][http://www.youtube.com/user/pulitovr#p/u/7/rDcxp-u299A[/video]
haha
1.513
4.448
10.72 128.8
didn't mess with the shocks, still set for ETdrags. Only got 3 passes in on 275 tring to get it setup better for the import vs domestic at MIR.
tires 15-16 psi.. seamed to work good? 275 MT on 15x10s
6 comp-8 rebound- rear strange DA
1 front strange SA
2step at 5500 I think 1sat pass. I really thought it was gona spin and I would have to pedal thu 1st. But it didn't
2nd pass turned 2step up to 5700
spin, But I drove thu some mud in the pits and washed it off half ass in a puddle in the lanes.
1.70
11.03 @ 129 or somthing?
http://www.youtube.com/user/pulitovr#p/u/9/ueoptQMQbmc
3rd pass went back to 5600, kinds bogged. but was pulling to right till I got 2 hands on the wheel after 2nd
1.497
4.537
10.82
128.2
http://www.youtube.com/user/pulitovr#p/u/2/jRHCOCWtWX8
Looking for some help
RED ROCKET
nice car man...not many imports will even try to race you.lol
What rpm are you taking off at?
SOFA KING WHAT?
Tire shake with the radial tire is usually cured by one of three things or a combo:
1. Hit the tire with more power
2. Stiffen the rear shocks, radials like a softer rebound and a tighter compression than bias tires
3. More rear tire air pressure
You might try footbraking it. Personally, I like footbraking my drag radials. You don't cut great lights if going off a pro tree, but you'll hit the tires smoother and more consistantly.
That may be tough for him to do, it's a 6 speed.
Discussion Starter #10
thanks
Is that tire shake? is was smooth in the car, The 2nd vid I think was just spinning.
1 ya I hear that form some guys. Its a stock headed, NA LS1. 440whp is all I got captin' More RPM on the 2step I guess?
2 ya I hear that too, the rear stiffin the comp up more, loosen the rebound,. The opposite of what Etdrags liked
SOFA KING WHAT?
Here's the deal on the shock and radials:
Softer rebound allows the chassis and suspension to set the tire, tight compression will hold the tire on the track.
1 - 11 of 11 Posts
