1 - 4 of 4 Posts
Hey guys, what is the part number for the 40amp Bosch relay everyone uses and do they allready have a diode inside?
Also, does anybody have or know where a wiring diagram is using the
ST-85 continuous duty relay from NAPA is? I need it to include a transbrake set-up.
Thanks a bunch.
Here are the ones I use.
Bosch High Capacity Relays
50amp rating. These relays have a resister in parallel with the coil to limit EMI.
Bosch part numbers
0 332 209 138 5 terminal with bracket mount
0 332 209 137 5 terminal no mount
Go to this site. http://www.waytekwire.com/index.htm
Click on products, select a catagory- relays, high capacity, and click on any relay.
From there you can click to open up their catalog page. Their is some more info available there.
1 - 4 of 4 Posts
