1 - 2 of 2 Posts
Hello guys,
I´m finishing my build and want to hear you about how to build boost on the footbrake.
Engine is a 390" with 86/91mm single turbo. My torque converter has 3500 rpm stall.
Using FT450 ECU so I can work on 2 step.
If I retard timing during 2-step should I remove enough power to not drag the car during stage and build boost for a good launch? In previous setup I was draging the car after 2200rpm when footbraking but I didn't have opportunity to work on 2-step at that time.
Want to hear your opinion,
Thanks,
I hope some knowledgeable members offer up their thoughts on this eventually. GREAT question! Albeit there may not be many foot brakers on here.
1 - 2 of 2 Posts
