1 - 4 of 4 Posts
How do you mean "needed"? It will make more HP at any boost level, if that's what you mean. The higher the boost, the hotter the air coming out of the blower and the more potential gain. If you want a number, I'll throw out 10-12psi.
The standard answer applies here: it depends. Higher compression requires an intercooler sooner than lower compression, cam design is a factor, fuel used etc.
Motor is built for boost with under 9-1 comp.Ill add intercooler later just courious how it would do on 110 and 15psi.Thanks
1 - 4 of 4 Posts
