How do you determine the limit of how much boost you push through a turbo even with CO2 on the gate?
Current I'm running twin JGS 50mm gates with a FI S476 Gangster turbo. I have medium springs in the gates and it makes 7-9psi on WG. If I throw 30psi on top of the gate via the boost leash it will make 24psi. If I throw any more one of 2 things happens: there seems to be a limit in the leash because 35, 40 or even 50 psi will not make any more boost and it stays at 24psi OR the leash will reset at 30 and not allow me to add more CO2 (I only noticed it when I power it down and power it back up). I'm only trying to push 28-30psi which I know the turbo should be able to do and I've seen 25-26 before.
Any feedback? If I'm leaving out information let me know, thanks!
