1 - 4 of 4 Posts
I have a Eboost controller. I have twin turbos, have 2 solinoids
ran in parallell(sp). The controller worked great the boost started
spiking. Checked the solinoids 1 was bad replace it boost still
spikes?
The controller(gauge/head unit) seems to have lost it's mine. Will
not change or aloow you access to set points?
I have checked wiring and the vac/boost line that runs to the unit.
ANY HELP would be greatly apprciated.
By the way GREAT SITE and alot of NICE CARS
AMS 1000
In order to access your setpoints, you need to press the mode and down arrow at the same time. If you dont press them at the same time, it takes you to peak boost recall (PBR).
You can tune out your spike by adjusting the gate pressure setpoint (GP) of the boost group you are in - lower the GP setting.
1 - 4 of 4 Posts
