True. From what I always see though, he is usually very busy, and I have no idea what the lead time would be. I also could just do it myself, but the jigging and fixturing may not be worth it for just one housing.Just go up RT5,and have Markow build you one.
You`d save alot on shipping,plus your supporting a local business.
I run one of TRZ's bolt in A-body housings in my car. It's a very nice piece. Couldn't be happier with it!I plan on ordering a full front and rear control arm setup from TRZ, but didnt see anything about housings on their site. I would rather get a housing through them if possible. I want to support companies who support the racers...
The longer you wait to call the later it will be.He is usually real good about how he schedules things.The quality is tough to beat,besides that if something should happen he is local.I bought a DTS housing and after assembly and installation I founf one of the brackets for the lower control arm/shock mount was welded on wrong and the right side is back almost 3/8" from the left.They wanted me to gut it ,clean it and ship it at my cost so they could "inspect it" and determine if there was a problem or not.True. From what I always see though, he is usually very busy, and I have no idea what the lead time would be. I also could just do it myself, but the jigging and fixturing may not be worth it for just one housing.
:smt023 Looks good!TRZ hands down, they did an awesome job on mine , excellent craftmanship. Heres mine with the backbrace, coil over brackets, uca and lca adj brackets. Using it along with there lca and uca's.
