1 - 5 of 5 Posts
Does anyone know if the top hole on the front of the fuelpump extension is blind tapped or not?
Its hard to describe but there are two bolt holes one above the other sits right behind my radiator hose on the passenger front. There are two bolts on the other side as well but both occupied by my alternator bracket. This is a 010 block if that makes a difference.
Thanks!
And I will add that if you still run the mechanical fuel pump make sure you don't put to long of a bolt in there cause it will lock the pushrod up. And then the fun will begin!
Thanks as embarassing as it is to say Ive had a small leak for a looong time and tried everything under the sun to stop and today it really looked wet at the base of that hole and so I threw a bolt with thread seal in just because but wasnt sure if it went threw or not. Thanks alot!
The hole is open so you can use a long bolt in it to hold the pushrod up when you change the fuel pump.
1 - 5 of 5 Posts
