im working on a 753 bobcat. replaced all filters, fuel bulb,lines,lift pump,in tank pickup,fuel cap, and oil. it runs good up untill normal temp and then gets low on power, it used to stall out completly spit and spudder unless you squeese the bulb. now it runs much better and doesent die, but like i said, loses power and under load will stall to a very low rpm. once it does this, it has a rough idle untill you sqeese the primer bulb, idle picks up and smoothes out. machine does not smoke.........wtf lol!!! any sugjestions are very apriciated, thanks:smt102
