1 - 18 of 18 Posts
I inherited this boat, its 3 hours away. I was told its just a 40hp sticker / cover and its bigger. Can anyone tell by looking at it what HP it really is?
93470
Some will. There is a lake here that has a max hp limit. Some people will change the cowl to meet the requirements.
Thanks for the info....my boat is only rated for a 175....a 225 would be amazing....might look into this when its time to repower
#Tittipicsmatter !
Be careful if you do. That 50hp may put you in a chine walk at WOT that you may not be able recover from. Then again it may be a ball of fun.
If it's a 40hp cover, chances are that it wont be much more than a 60hp.
From what I've read, my new 115hp Mercury is basically a 90hp with a hotter tune. Step up to the 150 from mine and it's a significant difference in outboard size.
Yep, thats whats sucks....have to buy the motor to find out if the boat likes it....its a big walleye boat....WOT now is 50mph....kinda boring, but then again, its a fishing boat
Discussion Starter #12
Yes but the diff between a 40 and 60 is about $2000
93611
I'm a long time merc dealer and mechanic. That's a mid to late 90s/early 2000s model and could be a 40, 50, or 60. All the same motor with different carbs and porting. Those were good little engines. 40s are most common and the 60hp version is the least common.
As just stated.. it’s and elpto 40/50/60. Look out for fuel pump diaphragms, voltage rec/regs and stators. The floats are also known for filling up with fuel. Make sure not to use a deep cycle battery or a fire may ensue. Die hard motors If those things are updated.
I see we have some knowledge here on boat motors eve with the lack of a boat section....i have a key west with a 60 merc on it thats been sitting in my yard for 6 years due to me buying my ranger....im in the slow process of redoing it from wires to paint....what eould y'all recommend me doing to motor before i get too far along
1 - 18 of 18 Posts
