1 - 5 of 5 Posts
ok fellas i have a single turbo kit from bg and a 70mm turbo . my question is i have a 9psi spring in the blowoff valve and a 11 1/2 pound spring in the wastegate does this make for any issues . i took the car for a long spin got on the car (wot), my boostcontroller is completly closed meaning i am only running spring pressur i see the 11 1/2 of boost on my gauge but i dont hear the blowoff valve open . its a tial 50mm blowoff and the wastegate is a 38mm tial . maybe its opening and i just don hear it ? thanks
im going to guess you have the hoses hooked up wrong. or its not bleeding off much air and you just cant hear it
BOV springs are unrelated to boost, they are matched to the vacuum the motor makes. With a 9 psi spring, you would need to make about 18" of vacuum to open it. I usually run the smallest ~6 psi spring since I see 10-12" of vacuum. Something to look into anyway.
yeah i remember cutting down mine now that you say that
1 - 5 of 5 Posts
