1 - 10 of 10 Posts
I have a new sbf turbo combo and I took it out for the first time last night.... I only have 1 valve cover breather and it blowed out and puked oil everywhere..... I need a breather in the valve cover.
What others solutions are there? thanks
forgot to mention it is a blowthrough on alky..... It was WAY rich so that may have had something to do with it as well..... I was only running 8 lbs and the plugs looked like they came out of the box, no cadmium burning...
Custom Engine Shop
You need at least two breathers. Since your running alky a Star Machine Vacuum pump is what is needed to try and keep the oil clean.
On the flow bench
or a breather from the valley...
Nope, the downpipe is on the wrong side of the piston. :)
1 - 10 of 10 Posts
