1 - 3 of 3 Posts
Im looking for a good blower carb. My setup is 383 sbc 8.5:1 compression, afr 210 heads, bullet solid roller cam 268/[email protected] and .680 lift. Its a light drag car that weighs about 2600 pounds with driver and an auto tranny. Blower will be a 671 and i plan to run a good amount of boost. Im trying to figure out if should run just a normal carb or a blower custom carb. Just dont wana lose power because im running the wrong carb. Any input is appreciated!
If you know how to tune a carb, you should be able to figure it out. If not, buy a good one. I just use two 600 vacum secondary holley's, because they were here ....
1 - 3 of 3 Posts
