1 - 3 of 3 Posts
was wandering about e85 blow thru carb.i got a holley carb modified by underpressure performance.which started out as holley 4150 hp.what would it take to convert to e85 and can i do it myself.was wandering jet sizes and etc.the motor its going on is as follows
388 sbc
vic jr intake
trick flow heads 2.02 1.60
all forged internals
comp off shelf turbo cam.600 lift range if remember.been awhile
new s480 from jose at forced looking at the most i can get out of it in the 8th mile
any help will be greatly appreciated and power of the bullet is always a plus.comments suggestions?
It depends on what they did to the carb! E85 will require 30-50% more fuel in all areas of the carb (idle, transition, PV's, mains). What boosters are in the carb?
i got it from justin burgess from shadyside.im not all sure what they did to it.need to have someone check it out.just like to go to e85.he is buildnig twin turbo camaro and belive he going efi but not sure so i got this off him at a good price and works well with race fuel just like to convert to alternative fuel.e85 or alcohol.
1 - 3 of 3 Posts
