1 - 8 of 8 Posts
I have a 555ci BBC with 8.2:1 cr, Dart CNC'd Pro1 355's, and the cam is a custom grind from comp. with a 114 lobe sep., 715 lift, 260's duration, 112 intake centerline and 4/7 swap.....What size carb am I going to need for this combo?
Will be in a heavy truck, and will be street driven, power tour, drag week, pump gas drags, etc. Any help would be appreciated. Thanks guys!!!!
Custom Engine Shop
Over 2000 hp can be supported on a 4150 carb BUT, you may find a Domi based carb will have less restriction and flow better.
What is the set-up, how much power?
I would go with a dom. 1100 is my first guess.
Custom Engine Shop
Sorry guys, forgot to add it is a single Precision 114mm, and I am looking for an IC3000 to use.
Hoping for as much power as possible...lol.
Single Domi will do. CSU or C&S
1 - 8 of 8 Posts
