1 - 9 of 9 Posts
im in the process of moving the bottle from the beed into the cab of my s10 and moutning it in place of the pass. seat.
my question is do i have to the blow down tube im sure i do need it
and if so do i have to run it threw the floor of the cab so it would spary out underneath the cab?
or can it just be mounted inside?
thanks
EFI/N2O JUNKIE
Use a -8 AN bulkhead fitting through the floor. I use -8 AN braided line to make it easy to swap bottles. You could simply use a hard line off the bottle and through the floor too.
i have the hard line that had the -8 fitting.
mainly looking to see what i ahev to do as far as rules and tech
X2 on the bulkhead fitting.
Discussion Starter · #7 ·
just went ahead and went with what Mike said...thanks for the help..made it easier also with the flexibilty of the line to remove the bottle
EFI/N2O JUNKIE
I originally had the hard line out the floor, but when I went to change the bottle the stupid line would slide-down and it was a pain to always get the bottle back in the same exact position all the time. The braided line is 100x easier, just cost a lot more!
Discussion Starter · #9 ·
ya i could tell when i had the hard line on the bottle and was trying to mark everything out that it would be a pain.
but good thing i had some line laying around
1 - 9 of 9 Posts
