The header configuration is going to depend on the type of cylinder head you would use.I figured it was a dumb question but I didn't know. So the block will fit in the same space as a 4.84 but the header configuration would be the only difference then.
But, yes, now that I think about it, it would have to change.The header configuration is going to depend on the type of cylinder head you would use.
