1 - 20 of 39 Posts
What heads and what plugs? Timing most likely. Are there any alum. specs on the plugs? Where is the timing mark on the other plugs?
SOFA KING WHAT?
What fuel?
How much compression?
SOFA KING WHAT?
What is your base timing and how much did you remove?
SOFA KING WHAT?
What's the tune up in the plate? Jetting, fuel pressure, nitrous pressure.
Track heats and a 23 plug? Are you sure? A aluminum track heat would use something more like a 3923. At any rate, both are projected tip plugs and shouldn't be used with nitrous. Also, 31* is too much timing (to start with) for a 150 shot. On a SBF, I normally start around 25* on a 150 and work from there.
This is sounding better to me as well.. ;) SJ
Discussion Starter #16
i run the digital 6 should i keep pulling it from the box or pull the base timing, are the 3923 ngk's
EFI/N2O JUNKIE
I think you can only pull 9.9 with the Digital 6. Why not lower the base timing some? You need enough timing to be able to do a clean burnout and stage, that's it.
Hey Drag Radial, your PM Box is full. Your wheels are on the way. Sorry for the slight thread hi-jack. ;)
Burnt plug is almost always a sign of too much timing.
1 - 20 of 39 Posts
