After talking it over we will keep the ultimate street name but if i catch any of you thieves stealing my M/T PRO 275 name in any way,shape or form there will be problems..................
Thanks to Alan Kennedy and Sean @ MEDIA 1 for making this possible.
As you will notice very little has changed except the tire rule and some wording. A couple of 50# weights here or there. Thanks everyone. I will look at the N/A combos and see if there is a place for them in this class. If we decide to allow them at certian weights then we will make an amendment to the rules no later than next week. We will not be changing rules for peoples cars that dont fit. 98% of these rules have been the same for the last 2 years and there doesnt seem to be any need for any real changes.
BILLET ATOMIZER INJECTORS
MEDIA 1
ULTIMATE STREET
32 CAR FIELD (150.00 TECH CARD)
5,000.00 WIN
1000.00 R-UP
200.00 SEMIS
150.00 1/4'S
100.00 1/8’S
Ultimate Street street is a heads up class designed for any passenger vehicle from any major manufacturer. Ultimate street cars are limited to a maximum cubic inch limit of 440 cubic inches.
Fiberglass/Carbon body panels are allowed. No one piece front ends. Cowl hoods may not be taller than half way point of the windshield. Forward facing scoops are prohibited.
Racers may have forward scoop if completely sealed/plugged.
INTERIOR
Aftermarket steering columns are allowed.
ELECTRICAL
Optical devices are prohibited. All entries must have operational head lights and tail lights.
ENGINE
Aftermarket blocks and cylinder heads are allowed. Entries may utilize a single carburetor or single throttle body (4150,4500 mounted) Motor plates and solid mounts are allowed. Engine must be in stock location. Mufflers are required on all vehicles except turbo entries. Entries must utilize a single stage nitrous plate with one nitrous, one fuel and one redundant purge solenoid. Foggers must be disconnected and all solenoids must be capped off. Nitrous plates using fogger nozzles are not allowed. All engines are limited to 440 cubic inches. Any engine in question will be measured with a P&G gauge. A correction factor of 1.5% will be used. Competitors may be asked to remove a cylinder head for bore and stroke measurements should any discrepancies arise.
POWER ADDERS
Nitrous - Progressive nitrous controllers are allowed.
SUPERCHARGERS AND TURBO ENTRIES MUST BE STOCK VALVE ANGLE ENGINES ONLY. NO ENTRY MAY HAVE ANY DEVICE TO DIRECT AIR INTO TURBO OR SUPERCHARGER PERIOD. NO CUTTING OF ANY HOLES ON FRONT END. STOCK FRONT ENDS WITH GRILLS/SLOTS ETC. ARE ALLOWED
WITH NO MODIFICATIONS PERIOD. A 50# WEIGHT PENALTY WILL BE ADDED FOR THESE COMBINATIONS IF TURBO/SUPERCHARGER IS FORWARD MOUNTED BEHIND GRILL/SLOTS/ETC
BOOSTED CARS MAY NOT USE ALCOHOL OR ANY OXYGENATED FUELS.( Q-16 ETC...).. ALL SUPER CHARGERS AND TURBOS MUST BE ORIGINAL FROM FACTORY AND TRUE SIZE.. NO REDUCERS OR BILLET WHEELS.
SB CHEVY 23 DEGREE
SB FORD 20 DEGREE
FACTORY HEADED SMALL BLOCK FORD MOD MOTOR
SUPERCHARGER MAX
F1A-3100 #
F1C - 3250 #
YSI - 3250 #
TURBO MAX
T-76 3100 # NO REDUCERS
T-80 3200 # NO REDUCERS
TRANSMISSION
Any OEM style automatic or OEM manual transmission is allowed. Manual transmissions must utilize an SFI approved bell housing.
REAR SUSPENSION
Stock type rear suspension only. Coil over shocks are allowed. Aftermarket replacement control arms are allowed.
WHEELS/TIRES
M/T TIRE PART # 3754R ONLY
WEIGHTS>
Base weight - 3200 lbs
All heads 14.9 and under - 3250 lbs
Any canted valve head - 3250 lbs
All heads 15 degrees and above carry no additional weight
Any 23 degree combo - 3000 lbs
BLUE THUNDER HEADS - 3300 lbs
Any 20 degree ford - 3000 lbs
C3,OLD STYLE YATES,C302,C302B - 3150
NO BILLET CYLINDER HEADS
Leaf springs -100#
MEDIA 1
ULTIMATE STREET
5,000.00 WIN
1000.00 R-UP
200.00 SEMIS
150.00 1/4'S
100.00 1/8’S
INTERIOR
ELECTRICAL
ENGINE
POWER ADDERS
SB CHEVY 23 DEGREE
SB FORD 20 DEGREE
SUPERCHARGER MAX
F1A-3100 #
F1C - 3250 #
YSI - 3250 #
TURBO MAX
TRANSMISSION
REAR SUSPENSION
WHEELS/TIRES
WEIGHTS>
Leaf springs -100#
