My block comes in soon. The specs below are what's on the receipt. I've always wanted to do a big cube LT1. What's reasonable for big cubes on the street? It seems anything with a 4.125" stroke gives me an unfavorable rod/stroke ratio. But I know people here have build some wild street engines.
Possible to squeeze a 6" rod with a 4" stroke or bigger on a standard deck SBC with this deck height?
Things to consider: I will be using E85 & a T56. Max bore can be 4.2" but probably will start out at 4.125" or 4.155"
SPEC EVOLUTION Iron Block:
• Gen2 LT1
• 9.025" Deck
• 4.120" Rough Bore
• 350 Main Journal
• Machined to Accept 1SPEC One Piece Rear Main Seal Adapter
• SBC .904" Lifter Bores
• 55mm Roller/60mm Babbit Cam Tunnel
• .391" Raised Cam Location
• 7/16" Head Studs
• Gen2 LT1
• 9.025" Deck
• 4.120" Rough Bore
• 350 Main Journal
• 7/16" Head Studs
