It depends on what head to a degree, obviously some heads are better than others. Most are designed as N/A heads and could stand some help on the exhaust side. On a turbo engine you can't just use a monster exhaust lobe like on a blower/N2O combo to help exhaust all the extra gas from the power adder. Since we are driving the turbo with this gas causing higher back pressure the exhaust lobe is very critical for top Performance with as little reversion as possible. This is where the port comes in. If you can make the exhaust port more efficient then you may be able to reap the benefits of the better flowing port and/or even run less exhaust duration depending on your goals. IMHO the exhaust port and cam lobe is more important than the intake on a turbo application so if you can improve it I would. However you can do a lot with refining the port shape keeping the valve size the same. I have a set of AJPE SBC heads that flow 325+ cfm using only a large stem 1.650" valve. Hope this helps.
