1 - 15 of 15 Posts
Have to give Mike a big Thank You!! We melted both sides of the aluminum exhaust on our camaro and he ran around between 12 midnight and 3 am scavaging up 4" tube/elbows and a welder and sawzall. We worked till 4:30am to get it all back together and wouldnt have been able to do it without his help!
Thanks Mike!
Team Lambert
just curious, what caused it to melt??:confused:
we had an aluminum 90* too close to each turbo and it pretty much melted/blew the back of each one out
it wasnt .120 i think it was .050 or .060
Thanks Mike!
Team Lambert
Mike and Karen will always come through when you need them,We have known them a long time and they are awsome people.
thanks for the info, got a friend building aluminum exhaust at the moment.... just hope he has the thicker 90's;) i will find out shortly.. thanks again:cool:
FYI, most of the twin turbo guys leave the turbo with a .120 wall elbow and change to the .065 wall downstream. Glad you got it back together.
Don't worry JG, Skinny has that down pat.
What thickness?
It was the .065" Basically straight out of the turbos after about 12" of straight pipe. It took several heat cycles before it blew out and only the 90* and the welds close to the 90* seemed to suffer. The welds close to the 90* and on the v-band seemed to get very brittle and the pipe broke off from the v-band.
Live and learn.:rolleyes:
Next time use titainium -- see you in a couple of weeks at the Shakedown
1 - 15 of 15 Posts
